Disables the tracking of an external gateway using ping.
| esrpDomain | Specifies an ESRP domain name. |
| ipaddress | Specifies the IPv4 address of the external gateway. |
No ping tracking.
If you disable ping tracking for a failed ping, the ESRP domain recovers from the forced standby state.
If you disable route tracking for a successful ping, there is no impact on the ESRP state.
The following command disables ping tracking for the external gateway at 10.207.29.17:
configure esrp esrp1 delete track-ping 10.207.29.17
This command was first available in ExtremeXOS 11.0.
